Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 I don't know that there is a real solution here... https://www.loom.com/share/acb90b94e619482db1f15ca503f22b9e Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Here I am messing with the Sash and Frame https://www.loom.com/share/89a52ff2afc8416bbfb5649fe75bb1ff Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 2, 2021 Share Posted November 2, 2021 So if you don't want the panels inside you might consider a Niche. The problem is that AFAIK you can't get a Niche to Mull with a Window. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 And another to fine tune this process... https://www.loom.com/share/1763931479674bf8ae2cf9d1c2a669c7 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 On 11/2/2021 at 9:45 PM, Joe_Carrick said: So if you don't want the panels inside you might consider a Niche. The problem is that AFAIK you can't get a Niche to Mull with a Window. Expand Well, let me try a niche and see what it does... I think I have some up with a pretty nice option (above) Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 2, 2021 Share Posted November 2, 2021 On 11/2/2021 at 6:18 PM, rgardner said: The wall material region was only to cut the brick material back to the sheathing layer. Expand Years ago, before we had Niches I created a block of a material region and a shape to work together. I think I still have some of those symbols so it's a distinct possibility. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 If it had a few more options that would work. The sill is also different for a Niche than a Window and doesn't offer the sash which creates the panel look. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 On 11/2/2021 at 9:51 PM, Joe_Carrick said: Years ago, before we had Niches I created a block of a material region and a shape to work together. I think I still have some of those symbols so it's a distinct possibility. Expand Hmmm. I will look into that. Maybe if something can be created that sinks into a wall, I could create a panel that could be sized to fit under a window. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 On 11/2/2021 at 9:51 PM, Joe_Carrick said: Years ago, before we had Niches I created a block of a material region and a shape to work together. I think I still have some of those symbols so it's a distinct possibility. Expand You might have something here... Could even be a raised panel Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 On 11/2/2021 at 9:49 PM, stevenyhof said: And another to fine tune this process... https://www.loom.com/share/1763931479674bf8ae2cf9d1c2a669c7 Expand I'm leaning toward this way. I would not mull the panels anyway and suppress the label. You can still mull the windows above it and it does not effect the windows panels. The panels can be on their own layer so they do not show up on the plan Thanks to everyone for diving into this!! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 2, 2021 Author Share Posted November 2, 2021 Another option with less panel layers and only using the polyline solid on the interior... https://www.loom.com/share/fc29e72e37ee488fa30e91f0cb4239b5 Link to comment Share on other sites More sharing options...
rgardner Posted November 3, 2021 Share Posted November 3, 2021 Really seems like you are not seeing the power of the cabinet along with the material Regino technique. No patching in the inside. If you want the sill add a molding on the cabinet as well. If you want more of a 3D look make the cabinet deeper and remove the doors set your stiles and rails exactly how you want them and place on top of a wall material region that will cut the brick away. Once you have the style of pattern you want it can be done in probably 2-5 minutes for the first one copied and pasted around as needed very quickly. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 3, 2021 Author Share Posted November 3, 2021 On 11/3/2021 at 12:10 AM, rgardner said: Really seems like you are not seeing the power of the cabinet along with the material Regino technique. No patching in the inside. If you want the sill add a molding on the cabinet as well. If you want more of a 3D look make the cabinet deeper and remove the doors set your stiles and rails exactly how you want them and place on top of a wall material region that will cut the brick away. Once you have the style of pattern you want it can be done in probably 2-5 minutes for the first one copied and pasted around as needed very quickly. Expand I will definitely look into this. I always thought garage doors could use an interphase like the cabinets. Thank you, Ryan! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted November 3, 2021 Author Share Posted November 3, 2021 On 11/3/2021 at 12:10 AM, rgardner said: Really seems like you are not seeing the power of the cabinet along with the material Regino technique. No patching in the inside. If you want the sill add a molding on the cabinet as well. If you want more of a 3D look make the cabinet deeper and remove the doors set your stiles and rails exactly how you want them and place on top of a wall material region that will cut the brick away. Once you have the style of pattern you want it can be done in probably 2-5 minutes for the first one copied and pasted around as needed very quickly. Expand Here is an example of what I believe Ryan is referring too... Worked very nicely. The one thing I also learned was that Material Regions will sink into the wall, that opens up some new ideas. https://www.loom.com/share/6ce866323d2c49008975346667443c32 Link to comment Share on other sites More sharing options...
rgardner Posted November 3, 2021 Share Posted November 3, 2021 On 11/3/2021 at 11:26 AM, stevenyhof said: Here is an example of what I believe Ryan is referring too... Worked very nicely. The one thing I also learned was that Material Regions will sink into the wall, that opens up some new ideas. https://www.loom.com/share/6ce866323d2c49008975346667443c32 Expand Just a heads up that you can mark the material region to remove finish layer or leave it in the dbx for the region. In this case I was using it to cut the brick layer to place your panel flush on the sheathing layer or on top of the house wrap layer. Link to comment Share on other sites More sharing options...
