Marvin stacked slider
MN_JohnH
For some reason the Marvin Window and door library has a stacked slider door but it is really just a 4 panel slider with two panels sliding out from the middle which is not what a stacked slider is.
I went to 3dwarehouse and they have the unit I want.
Question is, how do I make it act like a door where I can adjust the divided lites and trim and jams etc.
I have attached the file of the house with the door from 3d sketchup installed.
Thanks,
plan.plan
Use 2 sliding doors (1 right and 1 left )  Then move them together so that there's no space between the sliding panels.  You will need to move an exact distance - or maybe ctrl-drag.
Then mull them together.  This should give you 4 panels with just the 2 center panels openable.
Quote
2 hours ago, Dermot said:
If you want a sliding door with 4 panels that all stack on one side, you just need to set your door panels to 0-4 (or 4-0) instead of 2-2.
This is awesome, I was able to use the Marvin regular slider and modify it. I should have known it would be so simple.
Thanks!
