Designers_Edge Posted October 14, 2021 Share Posted October 14, 2021 I have changed nothing in any of my settings since I worked on this plan this morning. Now, when I go to my user library and the lighting I have saved there. I have red outlines on the majority of them and I have no idea why. Has anyone experience this? Link to comment Share on other sites More sharing options...
Kbird1 Posted October 14, 2021 Share Posted October 14, 2021 looks like you applied Red to the Electrical Layer while in a 3D Camera while working on something perhaps.... * make sure to reboot you computer when you see "weirdness" and make sure it is not just a Glitch too. ** added pic. M. Link to comment Share on other sites More sharing options...
Dermot Posted October 15, 2021 Share Posted October 15, 2021 I think Mick is on the right track. The part he didn't mention is that you may have accidently changed the layer color in your default template plan. This could also be a case of using the wrong layer set but again this might be something that you changed in your template plan. A couple of things to note: - The library browser keeps some things in memory, so closing and reopening the program can solve some issues. - The library browser should always use vector views for the selection panel. The preview panel can be set to display either vector views or render views. - Objects should always use the current layer settings to determine the color and line styles for the edge lines in vector views. - The library browser should get the layer information from your default template plan. - You might see the same problem if you just place one of these objects into a brand new plan and then create a vector camera view. - My best guess for why you have some objects that look different then others is that they are actually on different layers. For something other than guesses, you would probably have to post your template plan along with your user libraries. If you need additional help, you may want to contact technical support. Link to comment Share on other sites More sharing options...
