stevesakiwi Posted October 8, 2021 Share Posted October 8, 2021 Hi.... How do you adjust the height of the Terrain Flat Region?----there is no facility in it's data box to alter it's height. I have deleted the elevation data contained within the flat region but it doesn't seem to matter if the elevation is deleted or left as existing. Refer attached jpeg....the flat region is showing approx 4ft higher that where I want it to show the proposed ground level. If there is a video explaining this as well, I'd like a link please. Thanks in advance Link to comment Share on other sites More sharing options...
robdyck Posted October 8, 2021 Share Posted October 8, 2021 If I'm not mistaken, The Flat Region is a terrain modifier tool that will create a flat region that is the average height of the specified elevations around it. An Elevation Region allows you to set the elevation and create a flat interior. Link to comment Share on other sites More sharing options...
glennw Posted October 8, 2021 Share Posted October 8, 2021 You can't specify a height for a Raised/Lowered Region, or Flat Region - they modify the existing terrain height data and do not control it. If you want to specify a height, use an Elevation Region instead. I very rarely (never) use terrain modifiers - I always use Elevation Regions. 1 Link to comment Share on other sites More sharing options...
stevesakiwi Posted October 8, 2021 Author Share Posted October 8, 2021 Thanks guys.....that was quick. I'll investigate the elevation region facility. Link to comment Share on other sites More sharing options...
