Designer1 Posted September 17, 2021 Share Posted September 17, 2021 Does anyone know how to get chiefs pocket doors to line up with the airspace in the center of the wall versus the stud wall? I havent had to use these kinds of disappearing walls in chief, usually I use the stacking ones. Also, I know it depends on the width of the opening of the door but whats the normal wall composition for these larger pocket doors? Is it standard 6" double framing with the airspace in the center according to the width of the door size? Sorry to all the master framers... Im a designer so not always an expert on the framing details. Link to comment Share on other sites More sharing options...
glennw Posted September 17, 2021 Share Posted September 17, 2021 Chad, There is a setting called Offset From Wall, but it may not be much help. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 17, 2021 Share Posted September 17, 2021 In the Past I have just made one thick wall eg 16" and used notes/details per Manf. PDF etc M. Link to comment Share on other sites More sharing options...
Designer1 Posted September 18, 2021 Author Share Posted September 18, 2021 Thank you both for your replies, I like both suggestions and will give them both a try. Thanks again! Link to comment Share on other sites More sharing options...
