Addition that includes an atttic room
Walt_Alaska
New to CA Architect 2021. Doing an addition that includes an attic room. I'm having trouble matching the roof and cieling deminsions for that area. It includes a flat and angled cieling plus pony walls that are also exterior walls. See the sketch with finished interior deminsions. Any help is appreciated.
Why pony walls - I don't think you need pony walls.
Set your ceiling height to 53" (or whatever you need) and auto build the roof.
Turn off auto build roof.
Set your ceiling height to the flat ceiling height.
    30411
    sparky494
    sparky494
  • Similar Content
    • By Designer100
      I cannot get the breezeway roof on the opposite side to work and slope with stairs. I would appreciate any help.
      Colburn.zip
    • By allieceravolo
      I am looking for some help on a roof plan I am working on (copying a 2d elevation from an architect) and can't seem to get this to look right!
      (Also, I don't typically do exterior renderings and thought I would get some practice in - but clearly have no idea what I am doing :))
    • By Travis-Garcia
      I cannot seem to figure out how to make this exposed gable have the same shiplap siding on it that the house has. I built the patio piece by piece using framing members and added roof planes and ceiling planes then added the gable. Now II cannot figure out how to add siding.
      I'm using Home Designer Pro 2021
    • By Doug-ib
      First post here, this is my first attempt at roof truss. As you will see in the PDF attached the gables that are on the front of the duplex are being supported by the truss that are running in the vertical direction. I am wondering if this is normal as i cannot seem to create truss for the gables on the font of the home. If there is a more effective means of building roof truss for roofs of this style id love to hear them.
      truss question.pdf front view.pdf
    • By since1937
      How can I enclose the roof overhang so the beams/trusses aren’t exposed when walking outside from French doors? In the picture I colored in red where I’m trying to not have an open overhang. The overhang is 8’, and I will have structural posts to hold up overhang.
