john-ferguson Posted September 8, 2021 Share Posted September 8, 2021 in the attached drawing, I try to change the fascia colour of the back roof to match the rest, or chnge the soffits to non- boxed soffits, and the dormer disappears. Why is this? Link to comment Share on other sites More sharing options...
rgardner Posted September 8, 2021 Share Posted September 8, 2021 This would be the type of issue that someone needs to examine the plan in order to see what is happening. Link to comment Share on other sites More sharing options...
john-ferguson Posted September 8, 2021 Author Share Posted September 8, 2021 I would like to be able to do that but even zipped the file is too large to attach Link to comment Share on other sites More sharing options...
robdyck Posted September 8, 2021 Share Posted September 8, 2021 8 minutes ago, john-ferguson said: I would like to be able to do that but even zipped the file is too large to attach A download link is not too large. Can you use google drive or dropbox, or something similar? Link to comment Share on other sites More sharing options...
john-ferguson Posted September 8, 2021 Author Share Posted September 8, 2021 ok. here's a Ver 13 version of it https://drive.google.com/file/d/1tx3LkWrj4_6jDPVfW4FTfA4gyws0QX0C/view?usp=sharing and here's a ver 12 https://drive.google.com/file/d/1EzzRNcJuONiiFQ9AJOKZCwyN1eJMt6aF/view?usp=sharing Link to comment Share on other sites More sharing options...
rgardner Posted September 8, 2021 Share Posted September 8, 2021 17 minutes ago, john-ferguson said: ok. here's a Ver 13 version of it https://drive.google.com/file/d/1tx3LkWrj4_6jDPVfW4FTfA4gyws0QX0C/view?usp=sharing Tried to download but it is locked for those without permissions. Link to comment Share on other sites More sharing options...
rgardner Posted September 8, 2021 Share Posted September 8, 2021 Select the dormer and explode it first. Then change that errant roof plane fascia material. I wont get into other things that I see in the plan but I would advise you to be very careful with the MODE of the material painter tool. You have lots of conflicting materials/colors that you have mixed by using the blend colors with materials mode. This has conflicting materials across your defaults and it is resulting in some z fighting as well as why you couldn't just use the edit all roof planes tool to change that roof plane. The mixed colors was breaking the dormer material specifications. 1 Link to comment Share on other sites More sharing options...
john-ferguson Posted September 8, 2021 Author Share Posted September 8, 2021 Thanks for the advice!! exploding the dormer seemed to work... didn't even know that was an option! Link to comment Share on other sites More sharing options...
