RobWhite Posted August 23, 2021 Share Posted August 23, 2021 I am using the Chief X13 and trying to change my door opening indicators lines, so that my elevation view show the opening indicators point to the handles. Chief X13 only has a single selection options compared to previous version's dual options. The CA X13 'preference/Architectural/Legacy File Configuration/hinge opening: hinge indicators point to hinge' if unchecked should change my view to pointing to the handle but nothing changes; whether checked or unchecked. Unless I can get the opening indicators pointing to the handle side my builders will be confused. Am I not doing something or is this a program fault? Link to comment Share on other sites More sharing options...
glennw Posted August 23, 2021 Share Posted August 23, 2021 Rob, Have a look down at the bottom of this dbx: Link to comment Share on other sites More sharing options...
RobWhite Posted August 23, 2021 Author Share Posted August 23, 2021 Is the a new place for changing the opening indicators and was it there in X12? Have only ever made this change in the preferences menu?. Thanks for the tip. Indicators change and everything is sweet. Rob Link to comment Share on other sites More sharing options...
glennw Posted August 23, 2021 Share Posted August 23, 2021 This explains what happened: Link to comment Share on other sites More sharing options...
Dermot Posted August 23, 2021 Share Posted August 23, 2021 This setting was moved from preferences to plan defaults. This way if you send the plan to someone else or a different computer, the hinge indicators won't change direction because the preferences are set differently. Link to comment Share on other sites More sharing options...
