Symbols in Elevation View
JDSScott
10 minutes ago, JDSScott said:
when I export it to PDF they disappear and the line work is very light and not crisp.Construction Drawings2.layout
Link is not working for the .layout file and the layout file needs the referenced .plan file to work.  You will need to save both of them and close chief to upload them.  You may also need to put them in separate posts to be under 14MB.
