Material Takeoffs
kristy3983
I have never really used the material takeoff list function on Chief but have a client that was looking to get numbers for siding. I have a 4" wood lap siding as well as a 12" board and batten. When I generated the material list, all it showed was the 4" wood lap siding. I opened a wall that had the board and batten, went down to the component tab, and the ID says siding, the size says 4", and the description says lap siding. Is there a way to change this so when I run the materials list it will separate the two? Thanks.
Yes , don't use the Paint Can Tool on Exterior Walls :)    instead make two different Wall Definitions and apply them as appropriate.
