PBR flooring color reflecting on ceiling
ksmonterey
Hi everyone,
Wondering if anyone has any suggestions on how to improve this view...
The flooring color is reflecting on the white ceiling, showing the ceiling with this strange beige color. Also the crown has some of that beige reflection. I have changed the settings to what was showing on the Chief Videos but that didn't help much...
My video card is not good enough to use the ray tracing feature for X13.
Here is the view and camera settings.
image.thumb.png.199832e4fb1960fd68d6477b9825d81a.pngimage.thumb.png.e9b16918919c03ff98d373b8c83c9178.pngimage.thumb.png.0c489432f8fe9fad362f5449336ee842.png
15 minutes ago, ksmonterey said:
Hi everyone,
 I see you don't like Chief's AO much either ( 8% )  :)
did you try turning the sun setting WAY down  ie 500 Lumen not 100,000
* at some point it's good to do your Forum Signature....so people always know what version you are using etc....
Mick.
Hi Mick,
Thank you!
The sun setting is at 500 lumens. And doesn't seem to make a difference, the reflection still shows even when the sun is off.
I'm new at this, I'm using version 13. But this file was first created with version12.
https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662
It is always best to post the plan if you can, there are just way too many variables, ie did you accidently spraycan the ceiling ?
The .Plan file can be attached to a post but the new Forum now only allows 14mb , so you may need to zip the file 1st, they compress well , however make sure the Plan is not open in Chief when you do it as Chief locks the file and the Zip will be empty. ( 0kb)
