Railing Newel to beam issue
jtcapa1
Go to solution Solved by Chopsaw,
12 hours ago, Chopsaw said:
Try adjusting the room height.  Hopefully there are no others issues that will be created by doing that. ;)
Thanks Chopsaw!  I was working till 10pm yesterday due to the heat outside, and my brain was not working right!  So that was a blonde moment.
Thankfully you saw the simple and obvious solution.  I owe you a coffee!
13 hours ago, jtcapa1 said:
I cannot find a way to drop the beam below the adjacent roof eave
Ahh... it appeared from the pic you attached in your OP that you only wanted the beam in that one section dropped
