Steve_Nyhof Posted June 28, 2021 Share Posted June 28, 2021 Hello, I have continually updated (exported) my layers, defaults, etc and imported them into older jobs where I am using the older plan for a new job. However, there are things I have done with my .plan template (always fine tuning) that have other things I would like to have for a new drawing. I even tried to copy the plan floor to paste into a new plan, but that does not work. When I draw condos, I use an existing plan, copy and rename for a new drawing. It would be nice as I learn more and fine tune things to have those things available. What do others do to accomplish this? https://www.loom.com/share/57602a5852f14e4ba4272bf383018a5a Link to comment Share on other sites More sharing options...
richoffan Posted June 28, 2021 Share Posted June 28, 2021 Have you tried File>Back up entire plan ? Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 On 6/28/2021 at 3:03 PM, richoffan said: Have you tried File>Back up entire plan ? Expand Not sure what that would do. I need to copy an old plan into a new template. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 On 6/28/2021 at 4:51 PM, solver said: What's stopping you? Expand My brain! Your question makes me believe I must be missing something obvious. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 No - see above image on my first post - it gives me an Db and does nothing Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 or... maybe it will still work - testing now Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 sure!!! now it just worked without a hiccup - cool!! Thank you Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 Db - Dialog Box Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 28, 2021 Share Posted June 28, 2021 Standard term for that in these forums is dbx Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 On 6/28/2021 at 5:07 PM, Joe_Carrick said: Standard term for that in these forums is dbx Expand Oh yes! Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2021 Share Posted June 28, 2021 In Older Versions of Chief you couldn't Copy Cameras AFAIR, so maybe that is the issue? M. 1 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 On 6/28/2021 at 5:27 PM, Kbird1 said: In Older Versions of Chief you couldn't Copy Cameras AFAIR, so maybe that is the issue? M. Expand That is good info - I will check that Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted June 28, 2021 Author Share Posted June 28, 2021 On 6/28/2021 at 5:27 PM, Kbird1 said: In Older Versions of Chief you couldn't Copy Cameras AFAIR, so maybe that is the issue? M. Expand Yes, so if you have sections (section lines) in your floor it will do nothing. Once I shut the layer off it worked. Thank you for that info!! Link to comment Share on other sites More sharing options...
