Real-time Raytrace RTRT Tips
Renerabbitt
X-13 RTRT, A breakdown from another forum in response to growing frustrations with RTRT.
(Items that are specific and searchable terms in CA have capitalized first letters)
There is nothing "wrong" with the new Astral PBR RTRT option. Better understanding of a modern rendering engine may help alleviate some issues. If you are feeling overwhelmed by this info you can always uncheck the option for the RTRT in your Rendering Techniques Tool. Feel free to contact me for support or advanced training.
• In RTRT a low sample rate is used in live camera views.
• For exported presentations images similar to a CPU-based RT, set your Maximum Export Samples as low as needed to eliminate fireflies and light leaks. The higher the sample rate in RTRT Rendering Techniques, the better the image(up to a point where benefits are negligible). This only applies to the Export Image Tool.
• A sample rate in basic terms is the number of samples from a camera of a given Objects Material ID as it applies to the geometry of an object, including colors, lighting, shadows etc. The more times something is sampled the less aliasing there exists in a final image.
• The more light exists in the scene the easier it is to Sample.
• You must supply ample light in adjacent rooms for the RTRT engine to properly process and "trace" your scene. Devoid of light, your exterior will be overly exposed, your interior may be underexposed, and you may have fireflies or light leaks.
• Ensure that your active Light Set is on and illuminating your scene, which is accessed a number of ways, one being the Edit Active View tool, in the Camera Panel, under the Lighting Section.
• With ample lights, an interior scene Rendering Technique Options might have an exposure from .15-.35, a Maximum Sample Rate of 500-1500, a Brightness between -10 to 0, a Backdrop intensity between 100-1000. This is not and never will be a universal setting, each scene needs adjustment according to the amount of light available to that scene.
• If your scene is underexposed you may need to adjust your lighting including the lumens of your light fixtures.
• Sun settings will do very little to help overexposure, underexposure, light leaks or any other trace related problems. This is the nature of a tracing engine.
• Live view will always be of lesser quality than an exported image using the Export Tool(because of the option to change the sample rate.)
• Typical problem causing issues:
Caustics, Lights near transparent or translucent surfaces, lights of high Lumen values in one room juxtapose to lights of low lumens in an adjacent room. High resolution bump/roughness/normals maps in materials. These issues all cause difficult scenarios for attenuation and aliasing.
Some of the fixtures being used are not optimized for this new engine. Consider changing the material properties of any glass that is in close proximity to a light source. Changing the glass material of a light fixture that is turned on in a RTRT camera from Transparent class to General Material with high Transparency can yield much more predictable results. Same goes for situations when inside cabinet lights do not show up in RTRT behind Transparent Class windowed cabinet doors.
There is a lot more to this, you can have some success with this info, but barely scratches the surface. For some incredibly good generalized rendering info, read the Thea Render Manual(free online) It has some fantastic info in it that applies to all rendering engines.
The following images are a RTRT with zero lights(screen clipped), an RTRT with lots of lights and same settings(screen clipped), and an RTRT export of the same scene
The last image has the backdrop turned up since the sun direction is not illuminating the backdrop. Backdrop setting of 1000.
204594973_10161206461482586_240480734556
203545577_10161206464132586_387813617066
203932259_10161206493037586_559290755129
201973397_10161206508867586_240720176242
  • Like 5
  • Upvote 2
  • 3 weeks later...
36 minutes ago, MarkMc said:
Note to check cap live samples or the GPU keeps running
That was my biggest takeaway from play around in the other Thread , I am glad I finally figured it out..... CA has it set to OFF by Default
https://chieftalk.chiefarchitect.com/topic/31348-pbr-w-realtime-ray-tracing-questions-in-x13/?tab=comments#comment-247146
I did discover playing around tonight finally that not having Cap Live Samples ON, on PBR-RT Technique Tab,  seems to be the Issue with the (my) GPU going to max boost and Staying there..... ( Is already enabled in Nashville plan I tried yest. )   and dropping the Daylight Backdrop intensity to 500  even though Sun is already on 500 helped with the Light Bleed ( and adding a few Recessed Cans helped to I guess too), Thx,
    33817
    Celtic101
    Celtic101
  • Similar Content
    • By AlamoChief
      I just bought a new LG 32" 4K monitor and found my PBR render speed was slower than on my 27 Inch monitor. I discovered that the size of the window affects the render and denoise speed. With the window size the same on each monitor the speed is equal. If I shrink the window size to about 8" of render display the time to render and denoise is almost instantaneous. If I have the window full size on the 32" display the time goes up to about 9 seconds to finish rendering and denoise. I now know that if I'm just looking around to see what the model looks like a smaller window will speed up the process greatly. I hope this helps to understand how the render speed works.
    • By Ange822
      Having issues with the Fireplace Flame Image not showing in PBR view, but shows in Standard view.
      Images attached of Standard vs PBR view. The image layer is turned on for both. Thanks in advance!
      Standard:
      Physically Based:
    • By vivianyang2020
      Is there anybody know the ray trace? My CA quit when I run the ray trace on my new MacBook Pro. I have no problem on 3D rendering, just can not run the ray trace. This is so frustrated!
      Is there any way can fix it?
      MacBook Pro whit M1 pro, 32/512.
    • By DeLayDesign
      Hey Experts,
      I've already reached out to Chief about this issue, but I was curious if I was the only one who is experiencing it.
      I've during a PBR when doing an interior Physics Based Render, the plant image files You can see through windows for exterior landscaping disappear.  Even though they are active.  Additionally doing exterior PBRs the plant files don't appear to be casing a shadow.  If I run a normal retrace everything works fine.  Plant files show up and plant files create shadows in normal raytracer.
      In my examples (no where near complete) you can see what I'm referring to.
      Am I the only one?
      Vector View Interior
      PBR Interior
      PBR Exterior
      Normal Raytracer Exterior
    • By MollyNDG
      I am having issues getting any PBR to send to layout and then export to PDF clearly. It will get pretty close to clear when I am in the camera view itself, but it will not resolve fully when sent to layout or exported to PDF. This is still a new feature for me and am trying to figure it out, so this last step really has me stumped. Not sure if it is my computer (also having the lovely crashing issue on a regular basis, but that is another topic altogether). I cannot load the plan file I am currently having an issue with as it is a client file (I understand this is not helpful), but here is an image of what I am getting. Any ideas of where to start are greatly appreciated.
      X13
      AMD Radeon RX 6700XT
      TEST.pdf
