TV SCREEN IN RAYTRACE
BruceKC
I've placed an image on a large projector screen in my plan.  the room is fairly dark, and I was hoping that the image placed on the projector screen would be bright as in real life, but it isn't.  Is there a way to do this?  Thanks.
1 hour ago, BruceKC said:
Thanks for he help, but it doesn't seem to make much difference.
It is a material you are using and not an image right ?   What level of Emissivity did you use and does it work in standard view ?
3 hours ago, Gawdzira said:
Looks similar in Standard view. My problem with this is the edges bleed a lot of light. I made the screen about 1/8" thick to try and eliminate the glow but that does not work.
That looks like an oil painting Alan.  Did you try a TV with a fame around it ?
