CaddCreations Posted June 10, 2021 Share Posted June 10, 2021 The lengths of framing members in schedules, i.e. rafters, joists, etc appear to be expressed in fractional inches by default. Can that be changed to be expressed in feet and fractional inches. Link to comment Share on other sites More sharing options...
robdyck Posted June 10, 2021 Share Posted June 10, 2021 9 hours ago, CaddCreations said: The lengths of framing members in schedules, i.e. rafters, joists, etc appear to be expressed in fractional inches by default. Can that be changed to be expressed in feet and fractional inches. It can, but it requires some heavy lifting. You'll either need to learn to create macros, or hire someone to create them for you, then modify your schedules to incorporate those new macros, and modify all the framing members by adding Custom Object Fields to place the macros. There's nothing good to say about the entire process. 1 Link to comment Share on other sites More sharing options...
glennw Posted June 10, 2021 Share Posted June 10, 2021 You MAY be able to do what you want by using the Material List where you can change the units and unit formatting. Link to comment Share on other sites More sharing options...
