RGWhite Posted April 29, 2021 Share Posted April 29, 2021 I upgraded to X12 and now when I get on Ruby all I get is the Tutorial with a dark gray screen. How do I get the "normal" screen that is blank with white background? Like it was in earlier versions. Link to comment Share on other sites More sharing options...
Dermot Posted April 29, 2021 Share Posted April 29, 2021 The output window has a darker background because it is not an area you can type in. You can input commands in the line below the console. The help button does a pretty good job of explaining this (but you may note that it is still using the old white background). Link to comment Share on other sites More sharing options...
RGWhite Posted April 29, 2021 Author Share Posted April 29, 2021 This is what I mean. Can't get out of it. Link to comment Share on other sites More sharing options...
RGWhite Posted April 29, 2021 Author Share Posted April 29, 2021 Trying to get it to look like the previous version of CA 9. In that it was just a white back ground. The tutorial will not go away so as to have a blank screen with white back ground. Link to comment Share on other sites More sharing options...
RGWhite Posted April 29, 2021 Author Share Posted April 29, 2021 Thanks.........I know I don't need a blank screen but it would be nice like before. I will have to live with the way it is. Link to comment Share on other sites More sharing options...
Dermot Posted April 29, 2021 Share Posted April 29, 2021 As far as I know, the only difference between the ruby console in X9 versus X12 is the background color used for the output window. As far as I know, the only way to clear the contents from the output window is to exit the program and restart it. Might be nice if there was, but that would be a feature request and I don't think anyone has ever asked for this. Link to comment Share on other sites More sharing options...
RGWhite Posted April 29, 2021 Author Share Posted April 29, 2021 My opinion is that black fonts on a white background is the way to go. Black on gray???? not as easy to read. Since upgrading I am going through the features and happened on Ruby and was surprised by the different look. I will look at the improvements to the text macro management. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 29, 2021 Share Posted April 29, 2021 Robert, Have you tried hitting the "Done" button? I'm not sure how you started the Ruby Console in Help mode (tutorial) but you can basically clear that gray area by hitting the enter key several times. The only entry area in the console is as Dermot indicated - the bottom "white" area. The gray area is basically a response to what you enter. Link to comment Share on other sites More sharing options...
RGWhite Posted April 29, 2021 Author Share Posted April 29, 2021 I hit the done button and nothing. I did close the program and restarted and this cleared the tutorial screen. I guess I will have to do this each time I want to clear the screen. Maybe this needs to be looked at by CA. Link to comment Share on other sites More sharing options...
