Balcony floor material is not showing up in the elevation view
MAP6933
Hi,
I'm learning LOL, that was the first thing I checked but it didn't do it. I'm assuming the layer would be Floor Surface correct?
FYI, I created a room around this exterior balcony, not sure if that has anything to do with it.
After I turned it on I was looking in my layout for the change and then I remembered I had to go to the actual elevation view and close it to save the change and update it to be seen in the layout view.
Things are so simple but in the heat of the moment it seem complicated LOL
Thank you for your help!
Expand
Glad it worked out for you.  For you to know.  There are two options in the layout view to refresh the views.  One in the top Menu bar that is Refresh all views (with option for live views or all views).  The other option shows up when you select the layout box in the edit menu at the bottom and looks like a black circle with arrows which will refresh that view.
