MAP6933 Posted April 24, 2021 Share Posted April 24, 2021 Pics below... Link to comment Share on other sites More sharing options...
MAP6933 Posted April 25, 2021 Author Share Posted April 25, 2021 Hi, I'm learning LOL, that was the first thing I checked but it didn't do it. I'm assuming the layer would be Floor Surface correct? FYI, I created a room around this exterior balcony, not sure if that has anything to do with it. Link to comment Share on other sites More sharing options...
Chopsaw Posted April 25, 2021 Share Posted April 25, 2021 13 minutes ago, MAP6933 said: FYI, I created a room around this exterior balcony, not sure if that has anything to do with it. Yes the Floor Surface will not display unless the Rooms layer is also on. Link to comment Share on other sites More sharing options...
MAP6933 Posted April 25, 2021 Author Share Posted April 25, 2021 Hi, is the pic below what you mean? Link to comment Share on other sites More sharing options...
MAP6933 Posted April 25, 2021 Author Share Posted April 25, 2021 20 minutes ago, MAP6933 said: I got it! It was was Chopsaw said but I didn't have it checked in the right view... Link to comment Share on other sites More sharing options...
MAP6933 Posted April 25, 2021 Author Share Posted April 25, 2021 Thank you Chopsaw! Link to comment Share on other sites More sharing options...
MAP6933 Posted April 25, 2021 Author Share Posted April 25, 2021 After I turned it on I was looking in my layout for the change and then I remembered I had to go to the actual elevation view and close it to save the change and update it to be seen in the layout view. Things are so simple but in the heat of the moment it seem complicated LOL Thank you for your help! Link to comment Share on other sites More sharing options...
rgardner Posted April 25, 2021 Share Posted April 25, 2021 12 hours ago, MAP6933 said: I remembered I had to go to the actual elevation view and close it to save the change and update it to be seen in the layout view Glad it worked out for you. For you to know. There are two options in the layout view to refresh the views. One in the top Menu bar that is Refresh all views (with option for live views or all views). The other option shows up when you select the layout box in the edit menu at the bottom and looks like a black circle with arrows which will refresh that view. Link to comment Share on other sites More sharing options...
