RL-inc Posted April 3, 2021 Share Posted April 3, 2021 Is anyone of aware of a way to add lites or grids to a shaped window similar to the one shown here. much appreciated Link to comment Share on other sites More sharing options...
RL-inc Posted April 3, 2021 Author Share Posted April 3, 2021 Thanks Eric- I went through the process as describe in the ref manual - seemed pretty straight forward but when I click load custom Muntins they disappeared? Tried on fresh plan with a typical wall set up also- same result. Maybe an odd setting somewhere? Link to comment Share on other sites More sharing options...
MPDesign Posted April 4, 2021 Share Posted April 4, 2021 I just used this feature last week, make sure you block your cad lines before trying to load them. It works here. Link to comment Share on other sites More sharing options...
RL-inc Posted April 4, 2021 Author Share Posted April 4, 2021 Thanks Michael- I made sure they lines were blocked and still they disappear when I click on load custom muntins- When I click unload custom muntins the block appears again. Is there possibly a setting in the window dbx I am missing? Link to comment Share on other sites More sharing options...
RL-inc Posted April 4, 2021 Author Share Posted April 4, 2021 Thanks Eric- that works - sort of See attached images if cad block prior to loading and then after loading when drag window size down an inch or so. The muntins are there but do not meet the frame properly- The window looks a bit off too. Link to comment Share on other sites More sharing options...
RL-inc Posted April 4, 2021 Author Share Posted April 4, 2021 Much appreciated Eric- will try and get it close enough to pass for now Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 4, 2021 Share Posted April 4, 2021 You’ve already drawn the lines, just convert to 3D molding lines. Not ideal I know, but probably better then changing the size of your window and ending up with muntins that don’t reach the frame. Link to comment Share on other sites More sharing options...
RL-inc Posted April 4, 2021 Author Share Posted April 4, 2021 Thanks Michael- That works - certainly looks better. Link to comment Share on other sites More sharing options...
