Amberries Posted March 23, 2021 Share Posted March 23, 2021 I created a two story ranch home that has a basement and a first level. I was able to create the foundation and interior fine but I need to put windows in the basement and cannot figure out how. The window will go on the interior walls but will stop at the foundation wall. I can create an egress on the outside with a hole through terrain build but the window will not go through the foundation wall. I'm guessing I did something wrong in the creation...but I am completely clueless. Any help would be appreciated, thanks! Link to comment Share on other sites More sharing options...
Amberries Posted March 24, 2021 Author Share Posted March 24, 2021 I think I have that checked...that's why I'm so confused. I don't know what I'm doing wrong... Link to comment Share on other sites More sharing options...
Amberries Posted March 24, 2021 Author Share Posted March 24, 2021 Link to comment Share on other sites More sharing options...
Amberries Posted March 24, 2021 Author Share Posted March 24, 2021 I wasn't sure if you were asking for the whole file so I just sent it. Thanks for your help newest addition.plan Link to comment Share on other sites More sharing options...
Amberries Posted March 24, 2021 Author Share Posted March 24, 2021 and just fyi, some stuff like the fireplaces are just placeholders to show existing structures. I know those aren't accurate. The structural stuff is what I am trying to figure out. Link to comment Share on other sites More sharing options...
Amberries Posted March 24, 2021 Author Share Posted March 24, 2021 And I sent the wrong shot of the window details, sorry Link to comment Share on other sites More sharing options...
Amberries Posted March 24, 2021 Author Share Posted March 24, 2021 wow, so awesome! I am so grateful! It's obvious I'm a total newbie but I learn quickly, so the tips you gave me were like gold!! Thank you so very much!! 2 Link to comment Share on other sites More sharing options...
LimitlessViews Posted February 15 Share Posted February 15 I’m having this same issue. How were you able to fix it? Link to comment Share on other sites More sharing options...
DBCooper Posted February 16 Share Posted February 16 This is why people that answer forum posts and then later delete their answers should be beaten with sticks. If you have a foundation wall that is concrete and a separate interior wall that is framed, you need to make sure the framed wall is right up against the foundation wall without a gap. If you need a gap, then you will need to make a new wall type that has the gap built in. If the walls are snapped together than the window should go through automatically. If it doesn't you can check in the window dialog to see if the window is marked as "through". If this doesn't help you solve your problem, then you probably need to post your plan. 1 Link to comment Share on other sites More sharing options...
ArmanChahal Posted February 16 Share Posted February 16 Did you draw your foundation walls on the basement level ? Link to comment Share on other sites More sharing options...
mtldesigns Posted February 16 Share Posted February 16 10 hours ago, DBCooper said: This is why people that answer forum posts and then later delete their answers should be beaten with sticks DEFINETLY.. it sounds like she was talking to herself. Instead of two walls, why not build one wall with all you need, using a concrete exterior and a furred wall on the inside? In the wall DBX, unlimited options for building this wall out. Link to comment Share on other sites More sharing options...
