Windows showing on plan view
BruceKC
I have a garage door on my house plan, and I placed 3 small windows above the garage door.  Now, the plan shows the garage door, but also shows the windows superimposed in plan view, which of course I don't want.  Any thoughts on getting them to NOT display in plan view?    Thanks.
The Draw Order tool appears at the bottom of the screen once you have selected an object
After you click on the tool, use these buttons (place your cursor over the tool for a description of it's function) to move the selected item to the front or back of your plan.
Hi Eric,  the draw order didn't do the trick.  Moving them to another layer worked except the entire window unit didn't go to the other layer, only the main part and now I'm not even sure what the pieces on the edge of th window are.  And if I find out, not sure how to move the windows to a different layer and then pick what's left and move it as well.  Very confusing.  Thanks though for your help.  I attached plan view.
