Brannan926 Posted March 14, 2021 Share Posted March 14, 2021 I want to make a room underneath my staircase, but I don't want that room to have walls. Instead I want to use it as a little nook that is open to the adjacent library. however, I want a wall at and above the level of the stairs. Picture to illustrate my problem. Link to comment Share on other sites More sharing options...
joey_martin Posted March 14, 2021 Share Posted March 14, 2021 6 hours ago, Brannan926 said: but I don't want that room to have walls. Then it isn't a room. Use polysolids if walls aren't working, but my guess you aren't really explaining the situation appropriately. Link to comment Share on other sites More sharing options...
Brannan926 Posted March 15, 2021 Author Share Posted March 15, 2021 If you reference the photo I attached, it might explain better. I want the area under the stairs to be a part of the room. So the area under the stairs would be enclosed on two sides only. Link to comment Share on other sites More sharing options...
Brannan926 Posted March 15, 2021 Author Share Posted March 15, 2021 I want a wall at the level of the stair steps and up. Right now you can see the stairs and into the room beyond them - I don’t want that. Link to comment Share on other sites More sharing options...
joey_martin Posted March 15, 2021 Share Posted March 15, 2021 Use a solid railing wall rather than an open wall. Link to comment Share on other sites More sharing options...
Dermot Posted March 15, 2021 Share Posted March 15, 2021 "...I want a wall at and above the level of the stairs" Assuming that I am understanding what you want, you might try drawing a normal wall next to the stairs (not under them) and then edit the shape in an elevation view to raise up and angle the bottom of the wall to match the slope of the stairs. Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 15, 2021 Share Posted March 15, 2021 16 hours ago, Brannan926 said: If you reference the photo I attached, it might explain better. I want the area under the stairs to be a part of the room. So the area under the stairs would be enclosed on two sides only. In the photo, are we looking at the stairs from the room that you want the nook in? Or is the other room with the arch opening the one you want to have the nook? Can you sketch a plan of what you want? Link to comment Share on other sites More sharing options...
