Material Display Issues
cjprowant
I am having issues getting materials to display correctly. This issue is present in all of my Chief x12 files.
Tablet Specs:
Surface PRO 7
Intel(R) Core(TM) i5-1035G4 CPU @ 1.10GHz   1.50 GHz
8GB Ram
64-bit operating system, x64-based processor
When I zoom in closely, the textures display correctly. These issues only recently appeared. I have been using this set up since last fall with no issues until recently. If you have experienced this, please let me know what the solution is. I appreciate your help!
When view loads:
When scrolled in:
This sounds like a problem with your video card drivers.  Maybe the drivers were updated recently?  You might need to go back to an older version.
At any rate see if this tech article helps:
https://www.chiefarchitect.com/support/article/KB-00106/troubleshooting-3d-camera-view-display-problems-in-chief-architect.html
If not, then you might want to contact tech support during normal business hours.
27 minutes ago, cjprowant said:
Thanks for the help. It was a Texture Compression setting issue.
Thank you for posting the solution.  Could you also let us know your video card specifications so this will benefit others in your situation.
