AlmiraDesign Posted March 7, 2021 Share Posted March 7, 2021 So the bedroom has a closet, a bathroom is on the other side of the closet walls. But I was wondering what was inside the walls of the two squares I have drawn out. It is all to scale to the existing closet. In addition to that - how would I visually represent/define these walls? Leave them as is, have them filled in? Much appreciated. Almira Chief X12 Link to comment Share on other sites More sharing options...
JJohnson Posted March 7, 2021 Share Posted March 7, 2021 Possibly a "chase", a vertical space in a wall that provides an area for pipes or wires to run through. It may run up a wall from the basement to the upper level of your home or the attic for an air conditioning system return air duct (the larger one), or plumbing vent pipe. If that is the case you could draw a cad circle inside and label it. 1 Link to comment Share on other sites More sharing options...
rgardner Posted March 8, 2021 Share Posted March 8, 2021 A lot of times an unknown or even known chase will be designated in 2d floor plan with a closed x polyline. 2 Link to comment Share on other sites More sharing options...
ACADuser Posted March 8, 2021 Share Posted March 8, 2021 If you want the chase to be open, make the room type "OPEN TO BELOW" Also you may want a copy of the wall type for a new one-sided wall & delete the inner drywall. This way the chase is closer to real-world conditions. 1 Link to comment Share on other sites More sharing options...
AlmiraDesign Posted March 19, 2021 Author Share Posted March 19, 2021 Thank you! That helped out a ton. ! I appreciate it, guys. Link to comment Share on other sites More sharing options...
