QualicoreHomes Posted March 6, 2021 Share Posted March 6, 2021 Hello, Hopefully I am not asking a very obvious question but several times now, I needed to have the back of a cabinet angled but was not able to shape the cabinet according to the wall it is installed against. I have attached a picture of what I am trying to do in this project. I searched "custom cabinets" on the forum and in the videos but that seems to provide information on how to customize a cabinet in regards to the doors. Does anyone have some advice or can point me in the direction where I can find info on this? Thanks in advance! Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 6, 2021 Author Share Posted March 6, 2021 I would like to make the cabinets according the red outline. With this plan I am trying to match an existing kitchen that was built. Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 6, 2021 Author Share Posted March 6, 2021 To avoid this Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 6, 2021 Author Share Posted March 6, 2021 2 minutes ago, solver said: Do you have a picture of it? Only this Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 6, 2021 Author Share Posted March 6, 2021 Thanks for that! I had hoped it could be done with the cabinet so that the base would line up but I guess there would be work arounds for that. However, with my question I had hoped to kill two birds with one stone because of similar situations that I ran into before. Any suggestions? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2021 Share Posted March 6, 2021 4 hours ago, QualicoreHomes said: Hello, Hopefully I am not asking a very obvious question but several times now, I needed to have the back of a cabinet angled but was not able to shape the cabinet according to the wall it is installed against. I have attached a picture of what I am trying to do in this project. I searched "custom cabinets" on the forum and in the videos but that seems to provide information on how to customize a cabinet in regards to the doors. Does anyone have some advice or can point me in the direction where I can find info on this? Thanks in advance! You can do this with Box Construction>Cabinet Corner Treatment>Clipped. Just set the appropriate corner width. One little downside though is that you need a cabinet on the opposite side as well to stop that corner from clipping. It cab be a very small cabinet and you can put it on its own layer and turn the layer off, but it needs to be there. Link to comment Share on other sites More sharing options...
MarkMc Posted March 6, 2021 Share Posted March 6, 2021 11 hours ago, QualicoreHomes said: Any suggestions? While it's possible to do this with a cabinets using a very narrow one at the wall it tends to not be stable, the front clip comes back or the back one goes away if you sneeze. So the fastest way to get a clipped back is to set up cabinet to have clip then convert to symbol. I prefer to have that with no countertop and use a custom counter after placing. I always allow at least 1" filler or extended stile or installers will complain. As to the Recessed Corner sink base. Here's one I made since I have done enough of these to bother. NOTE that the back NEVER ever goes all the way into the corner (all mfg make them like the attached). Attached plan has one as shown, set to use default cabinet/door material, and another that is a block with countertop. There is also a pline of the correct outline of the cabinet. clip cab.plan Link to comment Share on other sites More sharing options...
QualicoreHomes Posted March 6, 2021 Author Share Posted March 6, 2021 Thank you all very much!! You people are amazing with your knowledge and willingness to share! Learned something new again as I had never used the clipped option before and thanks for the plan/cabinets Mark! Link to comment Share on other sites More sharing options...
