DzinEye Posted February 25, 2021 Share Posted February 25, 2021 I think this might've been asked before but I cannot find it. I want to create a copy of my current plan using Save As, but I don't want all my drawing links in the Layout to get updated to the new plan version. Usually I do want that behavior but in this case I do not... so how can I prevent it from happening? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 25, 2021 Share Posted February 25, 2021 Use Windows Explorer to copy to another folder and then rename that copy. Link to comment Share on other sites More sharing options...
DzinEye Posted February 25, 2021 Author Share Posted February 25, 2021 24 minutes ago, Joe_Carrick said: Use Windows Explorer to copy to another folder and then rename that copy. Thx Joe. Hmm....seems odd there isn't a built-in way to do it. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 25, 2021 Share Posted February 25, 2021 Actually, if the Layout isn't open you should be able to use "Save As" for your Plan without it effecting the Layout(s). AFAIK, only the Layout knows what the linked files are. I don't think it's a 2-way street. Best would be to try it with a dummy Layout and Plan to see what happens. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 25, 2021 Share Posted February 25, 2021 1 hour ago, DzinEye said: I want to create a copy of my current plan using Save As, but I don't want all my drawing links in the Layout to get updated to the new plan version. Usually I do want that behavior but in this case I do not... so how can I prevent it from happening? If you do a Save As and change the Plan name, you will automatically unlink the new plan from the layout file. Chief has a goofy behavior though where the open layout will start displaying information based on the current plan file. The links are only temporary though and have not actually been changed. To address this, I usually just close the layout down and then open it right back up. Been that way for a long time. I really should report it. I don't like it. Is that what you're talking about? Link to comment Share on other sites More sharing options...
DzinEye Posted February 26, 2021 Author Share Posted February 26, 2021 4 hours ago, Alaskan_Son said: If you do a Save As and change the Plan name, you will automatically unlink the new plan from the layout file. Chief has a goofy behavior though where the open layout will start displaying information based on the current plan file. The links are only temporary though and have not actually been changed. To address this, I usually just close the layout down and then open it right back up. Been that way for a long time. I really should report it. I don't like it. Is that what you're talking about? Wow... yes, I didn't know it, but that's what I'm talking about. It happened to me a couple days ago, and since I didn't know that, I went through and relinked all the files in the Layout to the older plan file. Aye-yai-yai...that definitely is not a good behavior. So glad I got your explanation. I think this can explain many moments of absolute confoundment over the years. Link to comment Share on other sites More sharing options...
