renosud Posted February 25, 2021 Share Posted February 25, 2021 Hi, Does anybody know how to get rid of the projected door casing when door and window units are mulled? See photo. I cannot seem to get rid of the dividing casing or frame section even when mulled as a single unit. I must be missing something. I need it to look mulled in a single plane, with no projected casing from the individual units. Any ideas? Many thanks MULLED_DOORS_V1.plan Link to comment Share on other sites More sharing options...
SNestor Posted February 25, 2021 Share Posted February 25, 2021 @renosud - not sure you want to do this...but you should try "recessing" the door to the sheathing layer. And...it doesn't look like you have two "frames" abutting one another. Each unit (door and sidelight) should have a frame which would provide some thickness to the separation. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted February 25, 2021 Share Posted February 25, 2021 @renosudYou may have them too close to the door. Un-mull them, move the sidelights away and then move them back, just touching the door, and mull them again. I think they are too close to allow the framing to build like you want it. Attach the plan and someone will probably know in less than a minute. Link to comment Share on other sites More sharing options...
renosud Posted February 25, 2021 Author Share Posted February 25, 2021 High Ridge Runner & Mr Nestor, I have uploaded a sample plan with these conditions and added a photo of the result I want to achieve with all units in the same plane and no frame/casing projections. I have recessed to sheathing layer and tried moving and shunting the individual units, but it always results in the same projecting casing. It's as if the mulled unit retains the connecting frames between individual units instead of creating a single unit frame. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 25, 2021 Share Posted February 25, 2021 Open your mulled unit, click on the Options tab, and adjust your Mullion Depth>Outside to something like 200 mm. 1 Link to comment Share on other sites More sharing options...
renosud Posted February 25, 2021 Author Share Posted February 25, 2021 Fixed! Thanks so much Alaskan Son. Let me know if you are ever in the Montpellier area of France. Lunch on me. 1 Link to comment Share on other sites More sharing options...
SNestor Posted February 25, 2021 Share Posted February 25, 2021 What Michael ☝️ said... 1 Link to comment Share on other sites More sharing options...
renosud Posted February 26, 2021 Author Share Posted February 26, 2021 Sorry Mr Nestor, looks like lunch for two! Thanks for taking the time to show in the trial plan and in metric. Link to comment Share on other sites More sharing options...
