Member Statistics
Similar Content
By DJohnsonSC
I am trying to create a story and a half main house that has a two story gable roof addition. I have been able to create the story and a half with a 1 story addition but can't figure out how to add a second story to the addition. The main part of the house has a 10/12 roof (created by build roof options: move roof up 12', ignore 2nd floor). The goal is to have the main roof 10/12 and the 2 story addition a 6/12 gable.
Pics below are a quick mockup. One showing the successful story and a half w addition. The other a bit more unusual configuration that I may not be able to get past the building inspector.
Thanks in advance for any help provided.
By alexpwalsh
Up until recently, my reference display worked great exactly as shown in the help docs and videos. I have no idea what changed, but now it no longer appears in red, but rather in black and anywhere a line on the reference display coincides with a line on the displayed floor, the lines "obliterate" one another and there is no line shown at all. It makes for some very strange views that are uninterpretable, especially when windows are on top of each other. I attached pics to show what I mean.
In my layer display options, the reference display set looks normal. Everything is in red.
How can one "reset" the reference display to work as it does in a fresh plan?
By msshemwell
I have two different wall types here for a basement plan I'm working on. One is an 8" concrete stem wall with a 1 1/2" air gap, 3 1/2" framing, and 1/2" drywall. The other is a standard interior 6 wall. I can't seem to get them to play nice in the areas that they merge. Any help?
By Darrellx
I'm using home designed pro 2021.
Circled in the picture below is the area unfilled between the lower and upper roof where there is no wall. I can extend the wall inward toward the peak to close the gap, but then area below the gap is closed off. I've experimented, googled, and watched a bunch of video tutorials on roofs. Actually seemed like one of the tutorial videos had a similar issue, but the instructor kinda glossed over it and changed to pitch on one roof to make it look a little better before moving on.
After banging my head for a few days, hoping someone has the answer.
(plan is also attached for the image)
MissingGableWall.plan
By larsonem
Hello, I am looking for some advise on how to improve the intersecting roofs which will overlap gable roof onto the hip roof so water avoid the corner on an addition project for myself. In the "elevation" picture, the hip roof to left is existing roof that will be extended to insect the new addition gable roof to the right. We like floor plan layout and ceiling heights but having trouble getting the roof line correct. I have attached the plan file and some snapshots.
Second question: How would I create the roofline extension like the attached "roof line" photo?
Thanks for help.
Dugan #8D.plan
