since1937 Posted January 29, 2021 Share Posted January 29, 2021 My exterior walls aren't showing up in camera perspective. I checked the display options, and the wall layers are checked. Please help. This hasn't happened to me before. Link to comment Share on other sites More sharing options...
since1937 Posted January 29, 2021 Author Share Posted January 29, 2021 2 minutes ago, solver said: The problem seems to be your roof is sitting on the terrain. The walls still aren't appearing, only the foundation Link to comment Share on other sites More sharing options...
Kbird1 Posted January 29, 2021 Share Posted January 29, 2021 Or Using a Floor Camera shot on level 0 it will only show the Slab...... use a Full Overview M. Link to comment Share on other sites More sharing options...
since1937 Posted January 29, 2021 Author Share Posted January 29, 2021 1 hour ago, solver said: check the Ceiling Height It was set to 0", thank you for the advice. Have never had ceiling height set at 0" when building out rooms. Link to comment Share on other sites More sharing options...
rgardner Posted January 29, 2021 Share Posted January 29, 2021 53 minutes ago, solver said: My comment above about the roof was to get you thinking about why the roof would be where it was. Roofs build over walls whose height is controlled by the ceiling of the room they form. Of course this is with automatic roofs but looking at the picture I would venture a guess this was drawn manually??? Link to comment Share on other sites More sharing options...
rgardner Posted January 29, 2021 Share Posted January 29, 2021 11 hours ago, solver said: Manual works the same. Very true if the roofs are set to the correct height... Link to comment Share on other sites More sharing options...
since1937 Posted January 29, 2021 Author Share Posted January 29, 2021 Soon as I added the roof, all but 2 or 3 walls disappeared, taking the roof to the terrain. I checked the ceiling height again to see if its at 0", and its set at 120". I've attached the file. would you mind taking a look? Backyard Design.plan Link to comment Share on other sites More sharing options...
rgardner Posted January 29, 2021 Share Posted January 29, 2021 29 minutes ago, since1937 said: Soon as I added the roof, all but 2 or 3 walls disappeared, taking the roof to the terrain. I checked the ceiling height again to see if its at 0", and its set at 120". I've attached the file. would you mind taking a look? Backyard Design.plan As mentioned above your roof planes are set @ varying heights and below ground. Please do yourself a favor and try auto roofs. It is a really easy plan for auto roofs. Link to comment Share on other sites More sharing options...
