DaveHicky Posted January 22, 2021 Share Posted January 22, 2021 Can some one help me why live view detriates when you send to layout ? I want the quality of live view printed to layout and then to pdf . the same quality if you do a screen shot and send to pdf I think this is a fundamental necessity for the hole process to be able to print off acceptable drawings ! even if you set to plot options the there is still a lack of defined lines ,clarity Regards Dave Link to comment Share on other sites More sharing options...
joey_martin Posted January 22, 2021 Share Posted January 22, 2021 Without knowing the process you are using, there is simply no way to answer your question. Clearly elevations sent to layout work incredibly well, we are just going to need to know what you are doing to pinpoint what went wrong. Link to comment Share on other sites More sharing options...
Dermot Posted January 22, 2021 Share Posted January 22, 2021 See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-03064/live-views-on-layout-appear-blurry.html If not, then you should post a plan and layout that demonstrates the problem you are seeing. If all else fails, then you may want to contact technical support during normal business hours. Link to comment Share on other sites More sharing options...
BBoumaConst Posted February 2, 2021 Share Posted February 2, 2021 I know exactly what you are referring to. It also drives me nuts. There is no way to preserve the high resolution of the rendering when you send it to layout or import it as an image, even if you export it in the highest resolution CA is capable of. At least none that I've found. It seems like CA compresses the image no matter what once it is sent to layout. I usually end up doing a work around using Adobe Acrobat once I print plans as a PDF using a screenshot of the plan view rendering. Link to comment Share on other sites More sharing options...
KarenMM Posted July 29, 2021 Share Posted July 29, 2021 Quote See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-03064/live-views-on-layout-appear-blurry.html I read this article and plot lines is grayed out under Camera View options Link to comment Share on other sites More sharing options...
