since1937 Posted December 24, 2020 Share Posted December 24, 2020 Is there a way to take this arc and replicate it for the remaining 3 corners so that its the same measurements at each corner? Link to comment Share on other sites More sharing options...
glennw Posted December 25, 2020 Share Posted December 25, 2020 This is my first thought. Just be aware that in recording the movie you don't get to see the pop up box that asks if you want to delete the original polyline. This will display once the intersection operation has completed. Say yes to delete the original. I will have to check and see if I can get that window to appear while recording. Any ideas Chopsaw - OBS? 25-12-20 Corners.mp4 1 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 25, 2020 Share Posted December 25, 2020 2 hours ago, glennw said: I will have to check and see if I can get that window to appear while recording. Any ideas Chopsaw - OBS? Are you using "Display Capture" for your Source ? It should work fine if you are. Window Capture will omit popups. Link to comment Share on other sites More sharing options...
glennw Posted December 25, 2020 Share Posted December 25, 2020 Thanks Chop Link to comment Share on other sites More sharing options...
