alexpwalsh Posted December 12, 2020 Share Posted December 12, 2020 Whenever I try to do a virtual walk through, I get these random flashes of interior wall and roof layers coming through. It happens with both interior and exterior walk throughts. It looks horrible, see the attached example. I've tried turning off all sorts of layers in the camera view - nothing seems to help and I can't find anyone else mentioning this on here so I figure it must be a setting on my end. Also have tried playing with frame rates and rendering options to no avail. Any ideas? Version: X12 Premier Student ext_walkthrough5.wmv Link to comment Share on other sites More sharing options...
glennw Posted December 12, 2020 Share Posted December 12, 2020 Do a search of the forum for "z fighting" 1 Link to comment Share on other sites More sharing options...
alexpwalsh Posted December 12, 2020 Author Share Posted December 12, 2020 Thanks Glenn! I think the issue is that my model is too far away from the origin. I have no idea how it got like that, but I am working on a plan that I made as a complete novice to the program so I'm not surprised. Now my issue is trying to pick up everything and move it closer to the origin. The Edit Area tool only seems to want to pick up the Floor I have viewable, even with All Layers ON. It will get the terrain and CAD lines as well, just not all the floors. How would one select and move everything on a plan.. Keep selecting and moving by the same coordinates using Transform? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 12, 2020 Share Posted December 12, 2020 There is an Edit Area (All Floors) option in the dropdown that should work for you. Also check your shingle thickness. I think the default is 1/8" but it really should be 1/4" and will render better that way. Link to comment Share on other sites More sharing options...
alexpwalsh Posted December 12, 2020 Author Share Posted December 12, 2020 Using Edit Area (All Floors) to reposition to the origin and upping shingle thickness to 1/4" seems to have done the trick. Thanks a ton guys, for bearing with the newbie. 1 Link to comment Share on other sites More sharing options...
