PMMully Posted December 3, 2020 Share Posted December 3, 2020 Hi all, two questions: 1) When I create window schedules on a detail page, I selected a plan/view, and it creates the schedule just fine. However, if I have more than one plan open, I was thinking it would take the last selected plan. I had to close the other plan to get it to work right. I was thinking my selection make the one plan "active". in this case, I had an as-built plan open and a proposed plan open, I wanted to generate the schedule from the proposed plan only. This is a minor nit but I figure there is a good trick out there. If I am in the proposed plan view, it generates the right schedule but puts it onto the view. 2) Given the scenario above, the proposed plan has a mixture of existing and new windows. When I create the schedule, it puts them all on the schedule. But what I really want is just the new windows. I looked at the schedule tool section of the reference doc but saw no answers. Custom schedule? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 3, 2020 Share Posted December 3, 2020 2 minutes ago, PMMully said: 2) Given the scenario above, the proposed plan has a mixture of existing and new windows. When I create the schedule, it puts them all on the schedule. But what I really want is just the new windows. I looked at the schedule tool section of the reference doc but saw no answers. Custom schedule? Each window has the option under the "Schedule" tab to include in Schedule or not. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 3, 2020 Share Posted December 3, 2020 If you don't get a quick answer on the other question you may want to participate in todays webinar. https://www.chiefarchitect.com/events/ Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 3, 2020 Share Posted December 3, 2020 Select the Existing Windows and unmark them as "Include in Schedule" 1 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 3, 2020 Share Posted December 3, 2020 You might not want to do that because the area of glazing might need to be included for energy calcs. Personally, I add a column (Object Information Panel) and specify "Existing" for those windows. That way there's no confusion. 1 Link to comment Share on other sites More sharing options...
PMMully Posted December 3, 2020 Author Share Posted December 3, 2020 3 minutes ago, Chopsaw said: If you don't get a quick answer on the other question you may want to participate in todays webinar. https://www.chiefarchitect.com/events/ I just registered, thank you. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 3, 2020 Share Posted December 3, 2020 12 minutes ago, PMMully said: 1) When I create window schedules on a detail page, I selected a plan/view, and it creates the schedule just fine. However, if I have more than one plan open, I was thinking it would take the last selected plan. I had to close the other plan to get it to work right. I was thinking my selection make the one plan "active". in this case, I had an as-built plan open and a proposed plan open, I wanted to generate the schedule from the proposed plan only. This is a minor nit but I figure there is a good trick out there. If I am in the proposed plan view, it generates the right schedule but puts it onto the view. I just wanted to be sure you are taking about separate plan views and not separate plan files ? If it is plan views maybe we answered your question already but if it is plan files it seems there may be a mystery here. Link to comment Share on other sites More sharing options...
PMMully Posted December 3, 2020 Author Share Posted December 3, 2020 18 minutes ago, Chopsaw said: I just wanted to be sure you are taking about separate plan views and not separate plan files ? If it is plan views maybe we answered your question already but if it is plan files it seems there may be a mystery here. It is actually plan files, separate files, linked to one layout for as-built/proposed. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 3, 2020 Share Posted December 3, 2020 Create the Schedule in the "Proposed" Plan. Then create a new CAD Detail Window and copy the Schedule to that Detail Window. Don't forget to delete the Schedule in the Plan View, otherwise you will get duplicate labels. You can use Ctrl-X and Ctrl-V 1 Link to comment Share on other sites More sharing options...
