Robb235 Posted December 1, 2020 Share Posted December 1, 2020 I'm not sure if a clicked a button or setting somewhere by mistake, but for some reason, I can no longer edit dimensions? I just get the clickies where I can drag the dimension around, but I can't edit dimensions anymore. For example, I was trying to edit the 11'-11 1/16" dimension in the picture below, but I no longer can for some reason. What happened? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2020 Share Posted December 1, 2020 What is it that you are actually trying to edit ? The measurement or the size of the room ? Also what version of the software are you using ? Link to comment Share on other sites More sharing options...
Robb235 Posted December 1, 2020 Author Share Posted December 1, 2020 The measurement. The 11'-1 1/16" dimension in this particular example. I'm wanting to move the wall. I am no longer able to edit any dimension anymore. I'm using Chief Architect X8. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 1, 2020 Share Posted December 1, 2020 You don’t select the dimension and edit it. You select the OBJECT that is being dimensioned. Then you can click on the desired dimension to change it. Link to comment Share on other sites More sharing options...
ACADuser Posted December 3, 2020 Share Posted December 3, 2020 As Michael said, click the wall followed by the dimension text. If it does not open for edit the dimension is not snaped to the wall. Link to comment Share on other sites More sharing options...
