davidstvz Posted November 19, 2020 Share Posted November 19, 2020 There are plenty of single and double doors in the libraries. There are also "segments" which you can use to construct a door by specifying the number of these segments that appear vertically. However, you can't specify the number of stamped panels that appear in such a segment horizontally. That's baked into the library choices and the only options are for 2 and 4 panel segments. What about 3? What about 8? They ought to just have panels ranging from 1 to 10 for completeness. I at least found a 5x8 panel door in a manufacturer catalog that works for my 18' wide door, but my 5x3 panel 6' wide storage garage door is left looking incorrect. Is there a way I can create a 5x3 panel door or 1x3 segment in some program to create a library object I can use? Or does anyone know where I can download one? EDIT: Sorry, I just realize there is a current discussion raging about this very topic over in Suggestions: Link to comment Share on other sites More sharing options...
Rich_Winsor Posted November 20, 2020 Share Posted November 20, 2020 This topic lingers like an unwanted virus. Do a forum search for GDW (Garage Door Wizard). After numerous resurfacings of the topic I have no idea where we stand on the availability of the program from the creator. PM me if you are interested in a free trial. GDW Test-2.calibz 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 20, 2020 Share Posted November 20, 2020 FWIW, you can make your own garage door panel symbols and then use them in the garage door dbx. 1 1 Link to comment Share on other sites More sharing options...
davidstvz Posted November 21, 2020 Author Share Posted November 21, 2020 @Rich_Winsor Thank you! @Joe_Carrick when you say symbol you refer to a 3D model? I guess I should look into how I can make my own from scratch. Hopefully HD Pro can do it some way, even if I need to work outside the program and import something. I don’t guess any external programs can operate directly on the .calibz files that Chief products use. EDIT: Ok, so "symbol" seems to refer to the special properties of 3D objects which are editable only in Chief, not HD Pro. HD Pro can import custom library objects, but doesn't seem to have any manner of creating them. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 21, 2020 Share Posted November 21, 2020 5 hours ago, davidstvz said: EDIT: Ok, so "symbol" seems to refer to the special properties of 3D objects which are editable only in Chief, not HD Pro. HD Pro can import custom library objects, but doesn't seem to have any manner of creating them. You should really be posting over in the HomeTalk forum... https://hometalk.chiefarchitect.com/?_fromLogin=CA3 That being said, Home Designer does have some options in this regard. Model your object using your available tools, take a 3D view, and then File>Export>Export 3D Model. You can then Import this same model as a symbol. 1 Link to comment Share on other sites More sharing options...
davidstvz Posted November 22, 2020 Author Share Posted November 22, 2020 Thank you. I will explore on my own some more this week. I am considering offering my services locally (and maybe online eventually) for basic rendering to help people visualize design choices in construction and remodel. So I may upgrade to chief at some point. I am using the chief demo, so I can justify posting here. The home talk forum is pretty barren unfortunate. It’s mostly just solver and DJP generously answering questions for people who don’t stick around. Link to comment Share on other sites More sharing options...
