jonow6 Posted November 11, 2020 Share Posted November 11, 2020 Anyone know of a quick way to change between wall types?.. I know you can just do Ctr+E and do it through the DBX, but just wonder if there is a way to put the wall type drop-down in a tool pallet. That way you could either select a wall in your plan and use the drop-down to change the wall, or if you have the wall tool active but don't have a wall selected you could change the type in the drop-down and that would become your default wall type. Opening and closing DBX's gets old fast 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 11, 2020 Share Posted November 11, 2020 26 minutes ago, solver said: Wall may be saved in the library. Once this is done you can Make your Own Toolbar(s) by assigning the different Walls to Place Library Icons but there is no way to make a Dropdown as far as I know..... ( I normally Drop a Empty Toolbar 1st then drop the other Place Library Icons onto it, to get one toolbar when finished ) *** No need for them to be "Default" this way 1 Link to comment Share on other sites More sharing options...
jonow6 Posted November 12, 2020 Author Share Posted November 12, 2020 Thanks guys, that is a good workaround. I have my common walls to my library w/ toolbar shortcuts. Was also hoping for a way to make changes to existing walls as well. Maybe it's something to pitch to CA. Wish the basic options weren't buried in DBX's... Link to comment Share on other sites More sharing options...
Kbird1 Posted November 12, 2020 Share Posted November 12, 2020 3 hours ago, jonow6 said: Was also hoping for a way to make changes to existing walls as well. Only way to do that is Change the Wall Definition the Existing Walls are using , so it changes then in Plan. AFAIK you can't group select certain Wall Types just Walls , you can't even pick exterior or interior only it seems by Shift Selecting them. M. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 12, 2020 Share Posted November 12, 2020 I put all interior walls on a different layer than exterior walls so I can just turn everything off except one layer of walls and select them all at once. You can set the layers in the wall defaults so it's automatic Link to comment Share on other sites More sharing options...
