Change extruded moulding profile to a solid shape?
Lakeside-E
  On 11/6/2020 at 4:02 PM, Alaskan_Son said:
That’s actually a pretty easy one. Just create that using a zero thickness polyline solid, explode, delete the unnecessary face, select the remaining face, and use the Revolve tool.
Expand
I've made a molding profile from the cross section and extruded it to my process 1 shape. The top and bottom are now oversized cylinders that need to be trimmed square. Doing it this way I only had to CAD draw my profile and save it as a molding profile then extrude it. I don't see how doing this from a solid would be easier to get to this point, just that it would be in the correct form to finish the next step. Can you help me understand your workflow?
Expand
This^^^^
...although I would probably make the box first and then a larger subtraction to act like a lathe.
  On 11/6/2020 at 4:33 PM, Alaskan_Son said:
This^^^^
Expand
I have done this method for making columns before to some extent and I understand the profile concept of a lathe so I am following you there, but how do I make my solid subtraction section cylindrical so that I could create the round profile I need in the center? Is there a tool that can extrude a solid the same way creating a molding will extrude a saved molding profile?
Expand
Read my second post again.
...Is there a tool that can extrude a solid the same way creating a molding will extrude a saved molding profile?
Expand
Expand
  On 11/6/2020 at 3:49 PM, Alaskan_Son said:
I just end up making these types of “moldings” out of solids.
Expand
Still not connecting your dots
Expand
Reading through...
Expand
create that using a zero thickness polyline solid...
Expand
...explode, delete the unnecessary face, select the remaining face...
Expand
...and use the Revolve tool.
Expand
Then of course I assumed you knew how to carry out the Subtraction...
  On 11/6/2020 at 7:29 PM, Alaskan_Son said:
It’s been repeated several times already.  The REVOLVE tool.
Expand
This was my misunderstanding... I assumed the revolve tool simply rotated a solid but apparently it does not act as I expected... Now to get a handle on the settings. Thanks for your help pointing me in the right direction
