Where to uncheck "Automatic Footing Bottom Height"?
DeltaHome
Just now, DeltaHome said:
Dang, I have been trying to drag up but that it is a little inaccurate for my abilites.
I really appreciate being told to stop looking.  Your reply has save me time and frustration.
Thank you.
If you are trying to manually step them instead of doing a room change in the crawl space grab the wall start moving in the direction you want then hit tab while you still have it held down and a box will pop-up allowing you to precisely change the step how you want it.
AKSon:  Yes, I do want the stem wall shorter as well. And my inconsistencies seem to be related to the two rooms.  So, I will try that.  Thank you!
RGardner:  Frickin' brilliant !!!!  Who knew that the tab could do that?  I like the idea of using "absolute."  I need to determine the difference between relative and absolute.
