BryceEngstrom Posted October 22, 2020 Share Posted October 22, 2020 In the attached Note Schedule, I want my callouts fairly large since it's a fairly big site at a small scale, but in the Note Schedule I want my text in the schedule to match the note symbol. I have tried the various options in the dbx, but I can't seem to find a way to make it so the font sizes are more the same. What am I missing? Thanks in advance. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 22, 2020 Share Posted October 22, 2020 Link to comment Share on other sites More sharing options...
BryceEngstrom Posted October 22, 2020 Author Share Posted October 22, 2020 Thanks, but all that does is make all the text, in both columns, larger. I just want the text in the right hand column to get bigger to match the numbered symbol in the schedule in the left hand column. Change your note text size in plan to 12 and see what it does to the schedule. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted October 22, 2020 Author Share Posted October 22, 2020 With my note callouts set to 12 for the site plan, this is how it ends up looking, with the Note Schedule taking up way more space on the page than it should. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 22, 2020 Share Posted October 22, 2020 Yours seems cramped for some reason. This is what mine looks like set to 12" for the Note and Schedule.... Not sure if this works for notes ? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 23, 2020 Share Posted October 23, 2020 2 things: 1. Try resizing that first column (width). 2. Try using the Scaling settings in the General tab of your Schedule Specification dialog. You probably want it set to Use Plan View Scale. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 23, 2020 Share Posted October 23, 2020 1 hour ago, Alaskan_Son said: You probably want it set to Use Plan View Scale. That is the difference. Resizing definitely does not work with a Note Schedule. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 23, 2020 Share Posted October 23, 2020 34 minutes ago, Chopsaw said: Resizing definitely does not work with a Note Schedule. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted October 23, 2020 Share Posted October 23, 2020 Ok so it does work if you turn off Scale Images but I don't think that is what Bryce was asking for. 5 hours ago, BryceEngstrom said: I just want the text in the right hand column to get bigger to match the numbered symbol in the schedule in the left hand column. Link to comment Share on other sites More sharing options...
BryceEngstrom Posted October 24, 2020 Author Share Posted October 24, 2020 On 10/22/2020 at 8:37 PM, Alaskan_Son said: That did it, thanks again. Bryce Link to comment Share on other sites More sharing options...
