Ronniesha 0 Posted October 16, 2020 Hi all. I am trying to poche/fill my walls on my lighting plan. Currently the walls show up as white fill and I just to want them to be a grey fill See attached photo Share this post Link to post Share on other sites
DzinEye 265 Posted October 16, 2020 You can either define the wall type to have grey fill in the wall DBX, or you can use the Hatch Wall tool Share this post Link to post Share on other sites
Ronniesha 0 Posted October 16, 2020 @DzinEye What does the wall hatch look like? Also I tried to change the fill on my wall specification but it doesn't show in my plan view Share this post Link to post Share on other sites
Chopsaw 635 Posted October 16, 2020 17 minutes ago, Ronniesha said: Also I tried to change the fill on my wall specification but it doesn't show in my plan view I think to make it show fill you need the Walls, Layers and Walls, Main Layer Only layers to be on at the same time. Share this post Link to post Share on other sites
DzinEye 265 Posted October 16, 2020 15 minutes ago, Ronniesha said: What does the wall hatch look like? Also I tried to change the fill on my wall specification but it doesn't show in my plan view If you specified fill and it's not showing, it's because of the wall display setting being used. Are you using the Saved Plan View for Electrical ? If so, it's not showing because the Walls, Layers layer is turned off. Turn that layer on. That is the easiest solution...but if you want to try wall hatch, go to the Build / Wall pull-down Share this post Link to post Share on other sites
Ronniesha 0 Posted October 16, 2020 @DzinEye Alright that worked! I didnt have the layer on! Share this post Link to post Share on other sites
