CJSpud Posted October 14, 2020 Share Posted October 14, 2020 When I use the tray ceiling tool, not only do I get a pink dashed line for the tray (stepped) ceiling I want in a room, but I also get a pink dashed line around the perimeter of the room my tray ceiling is built in. Is there any way to turn off the perimeter dashed line and just keep the actual tray ceiling as a dashed line or do I have to go back to doing a tray ceiling the old way? I really like the tray ceiling tool and the ease of use but I think the dashed room ceiling perimeter lines is a shortcoming of this feature - unless I am missing something somewhere that would allow me to turn this line off. Link to comment Share on other sites More sharing options...
DzinEye Posted October 14, 2020 Share Posted October 14, 2020 24 minutes ago, CJSpud said: but I also get a pink dashed line around the perimeter of the room my tray ceiling is built in. That outer line shouldn't show up when you print if you move display of those lines behind the wall lines... but if you just can't stand it anyway I wouldn't give up the tray tool... just trace the inner recessed shape with another layer named 'Ceiling recess' or something like that and turn off the ceiling plane lines. 1 Link to comment Share on other sites More sharing options...
DzinEye Posted October 14, 2020 Share Posted October 14, 2020 By the way... those pink lines aren't unique to the Tray Ceiling tool.... the layer is called Ceiling Planes... and any other manually drawn ceiling planes would automatically go on that layer as well. It's showing the whole perimeter of the polyline 'plane'... just like a roof plane would, except in the case of the tray ceiling it's showing the hole in the plane as well as the perimeter of the plane. Link to comment Share on other sites More sharing options...
CJSpud Posted October 14, 2020 Author Share Posted October 14, 2020 Thanks for your responses. I like your idea of a trace over and then turn the ceiling plane layer off. Link to comment Share on other sites More sharing options...
robdyck Posted October 14, 2020 Share Posted October 14, 2020 19 minutes ago, CJSpud said: Thanks for your responses. I like your idea of a trace over and then turn the ceiling plane layer off. Don't do that....just bump that sucker back to drawing order #27. 1 Link to comment Share on other sites More sharing options...
CJSpud Posted October 14, 2020 Author Share Posted October 14, 2020 Robert: Super idea ... why didn't I think of that ... before I did the trace-over? Next time. Thanks. Link to comment Share on other sites More sharing options...
robdyck Posted October 14, 2020 Share Posted October 14, 2020 1 minute ago, CJSpud said: Robert: Super idea ... why didn't I think of that ... before I did the trace-over? Next time. Thanks. I was wondering if my post would be in time! Luckily both ways work. Link to comment Share on other sites More sharing options...
DzinEye Posted October 14, 2020 Share Posted October 14, 2020 1 hour ago, robdyck said: Don't do that....just bump that sucker back to drawing order #27 1 hour ago, CJSpud said: Super idea ... why didn't I think of that ... before I did the trace-over? Next time. Thanks. I said that in my original response... without so many words... "if you move display of those lines behind the wall lines" Link to comment Share on other sites More sharing options...
CJSpud Posted October 15, 2020 Author Share Posted October 15, 2020 Mark: Indeed you did and thank you. It didn't register quite as strongly with me as Rob's actually suggesting what drawing order to use ... which is a feature I don't use as fully as I should. By the way, my youngest son is named Mark. Link to comment Share on other sites More sharing options...
