kwhitt Posted October 14, 2020 Share Posted October 14, 2020 I've got some ceiling trim that requires several compound angles. I have exported my model out as .DAE and opened in another app where I created this trim. Now I want to bring it back into Chief, but in the same world position so that I don't have to spend time placing it exactly where I want it. Is this possible upon import? Thanks, Kevin Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 14, 2020 Share Posted October 14, 2020 You can use this... 1 Link to comment Share on other sites More sharing options...
kwhitt Posted October 14, 2020 Author Share Posted October 14, 2020 58 minutes ago, Alaskan_Son said: You can use this... Thanks Michael. And when placing it in the plan, how do I ensure I click at 0,0? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 14, 2020 Share Posted October 14, 2020 1 minute ago, kwhitt said: Thanks Michael. And when placing it in the plan, how do I ensure I click at 0,0? That's really up to you. Place a temporary point at 0,0 is one way, or just select the symbol after you place it and use Transform/Replicate>Move>Absolute Location 1 Link to comment Share on other sites More sharing options...
kwhitt Posted October 14, 2020 Author Share Posted October 14, 2020 37 minutes ago, Alaskan_Son said: That's really up to you. Place a temporary point at 0,0 is one way, or just select the symbol after you place it and use Transform/Replicate>Move>Absolute Location Thanks again! Link to comment Share on other sites More sharing options...
kwhitt Posted October 14, 2020 Author Share Posted October 14, 2020 1 hour ago, Alaskan_Son said: That's really up to you. Place a temporary point at 0,0 is one way, or just select the symbol after you place it and use Transform/Replicate>Move>Absolute Location Michael - I can get the symbol built with the offset origin - first image, But when I place it in the plan view the origin is reset to center by the bounding box - second image. When I try to move to absolute 0,0,0 - it ignores the offset origin. What step am I missing here? Thanks! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 14, 2020 Share Posted October 14, 2020 The way it works in Chief is that the the 3D representation is offset, not the 2D block. It’s not a perfect solution. Check your 3D and see how that looks. By the way, this is yet another example of where we could really use a Convert To Symbol In Place functionality. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted October 14, 2020 Author Share Posted October 14, 2020 1 hour ago, Alaskan_Son said: The way it works in Chief is that the the 3D representation is offset, not the 2D block. It’s not a perfect solution. Check your 3D and see how that looks. By the way, this is yet another example of where we could really use a Convert To Symbol In Place functionality. That's crazy. It still doesn't align in the 3D view. Have tried various import formats. I was able to move it by gauging distances in elevation view. Guess it will have to do for now. Appreciate the help. Link to comment Share on other sites More sharing options...
DzinEye Posted October 14, 2020 Share Posted October 14, 2020 2 hours ago, kwhitt said: I was able to move it by gauging distances in elevation view. Kevin, could you import those along with another piece of geometry from the room that you could use to more accurately place it? Perhaps a diagonal line drawn to one of the corners of the room? 1 Link to comment Share on other sites More sharing options...
kwhitt Posted October 14, 2020 Author Share Posted October 14, 2020 22 minutes ago, DzinEye said: Kevin, could you import those along with another piece of geometry from the room that you could use to more accurately place it? Perhaps a diagonal line drawn to one of the corners of the room? Hi Mark. That is a good idea. I could choose a segment that fits neatly in the corner of a room. The 2D symbols not aligning with the 3D objects is a deal breaker for me to want to use this method in the future though... Thanks for you input. Kevin Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 14, 2020 Share Posted October 14, 2020 There are all sorts of different ways to do what you’re trying to accomplish, but here’s a video with one of my preferred methods. It was made for another situation but would work for what you’re doing as well... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 15, 2020 Share Posted October 15, 2020 9 hours ago, kwhitt said: The 2D symbols not aligning with the 3D objects is a deal breaker for me to want to use this method in the future though... Just FYI, if you’re properly syncing the origin in both pieces of software, things should align in 3D and you can actually fix the 2D by just copying the values from the offsets and just moving the object by those amounts instead. 1 Link to comment Share on other sites More sharing options...
kwhitt Posted October 16, 2020 Author Share Posted October 16, 2020 On 10/15/2020 at 2:50 AM, Alaskan_Son said: Just FYI, if you’re properly syncing the origin in both pieces of software, things should align in 3D and you can actually fix the 2D by just copying the values from the offsets and just moving the object by those amounts instead. Thanks Michael. I have checked that the origins are the same in both programs and it still doesn't align correctly in Chief. X aligns just fine, but Y and Z are off. It really isn't a big deal to move though. Good to know that I can correct the 2D symbol using the offsets. Kevin Link to comment Share on other sites More sharing options...
