Ronniesha Posted October 5, 2020 Share Posted October 5, 2020 Hello Does anyone have an idea of why my elevation symbols are different size? I have like really small ones, medium ones, and then HUGE ones. I just want them all to be the same size. I am sure it is something simple. See attached photo Link to comment Share on other sites More sharing options...
Chopsaw Posted October 5, 2020 Share Posted October 5, 2020 Take a look in the Plan Display section of the Camera DBX. You are asking chief to do a difficult task. It appears you have the callout size set to automatic and chief us expanding the callout so that all that text you have in the bottom line will fit within the callout. The automatic setting will also respond to the text size that is controlled by the layer. It would seem you need to make some sort of compromise. If you are going to use the automatic setting and want to callouts the same size then you need to come up with a coding system that uses the same number of characters for each callout. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 5, 2020 Share Posted October 5, 2020 Normally, the text below the line should be the layout sheet number. Link to comment Share on other sites More sharing options...
Ronniesha Posted October 5, 2020 Author Share Posted October 5, 2020 Alrighty - I ended up changing the name of the page and so it changed the size of the elevation call out! Link to comment Share on other sites More sharing options...
