BenReece Posted September 20, 2020 Share Posted September 20, 2020 I have several DXF files for a project I am working on that was sent to me by the architect. He is working in AutoCad and sent them to me in DXF format. Some of the DXF's I am importing into CA seem to be opening properly for the most part, but some appear blank. I do not have much experience importing DXF's to CA as I just moved over to CA recently. Any advice? I would be willing to import the files in DWG or convert from PDF and trace over if needed. Not opposed to doing a little more work as long as it gets done correctly. Would appreciate any advice on which method would be less of a hassle. I have attached 2 files in case anyone wants to give it a look. Maybe you might see something I am missing. One of them I am able to open and see the data and the other is showing up blank for me. The file "First Floor Plan" is the one that is showing up blank. "Lower Level Building Plan" is opening up fine. Any help is appreciated!!! Mountain View Apartments-Sheet - A-3-2 - FIRST FLOOR PLAN.dxf Mountain View Apartments-Sheet - A-3-1 - LOWER LEVEL BUILDING PLAN.dxf Link to comment Share on other sites More sharing options...
MarkMc Posted September 20, 2020 Share Posted September 20, 2020 On 9/20/2020 at 3:56 PM, BenReece said: The file "First Floor Plan" is the one that is showing up blank. Expand It also does not open in NanoCad, TurboCad and is a mess in DXF viewer. Something wrong with the file. Link to comment Share on other sites More sharing options...
BenReece Posted September 20, 2020 Author Share Posted September 20, 2020 I was wondering if it was a problem with the file. Thank you for that! Will see if the architect can resend or send in DWG. Thank you sir! Link to comment Share on other sites More sharing options...
Chopsaw Posted September 20, 2020 Share Posted September 20, 2020 I opened in Trueview and it said there were missing referenced files. The tilte block shows up in Layout but only a reference to some sort of .png file in model space. Not like the "LOWER LEVEL". 1 Link to comment Share on other sites More sharing options...
