Print settings
robdyck
>so that the print dialog is always correct for a particular layout file...
>I must be missing something simple...
Yes, sorry the meaningful description of the issue.
dialog settings, like what? Landscape, Printer Name, CollateCopies, DoubleSided, PaperOrientation, Watermark, Range, Scale, Print in Color...
12 minutes ago, solver said:
It would be convenient to be able to save a named Printer Profile so that selecting a profile would fill in the dialog.
I can't be the only one who'd like to save that time changing printer settings each time I use a different layout page. Seems like low hanging fruit, which is why I was wondering if I was just missing something obvious. HOLD ON...it would appear as though the EXPORT PDF may help here!!! I'll dig deeper.
@Renerabbitt
Export PDF tool helps with most of these except DPI apparently. It keeps coming up at 600, even after previous use at 300. The Print tool, however, remembers the last used DPI setting. Both different, both not helpful! They need to remember a DPI setting for that particular page setup.
