rwdozier Posted September 4, 2020 Share Posted September 4, 2020 I am changing some default settings to start a new plan and I don't know where the settings are to create a garage curb that extends past the interior wall. Could someone point me in the right direction? Thanks. Foundation_Test_Plan_03.plan Link to comment Share on other sites More sharing options...
rwdozier Posted September 4, 2020 Author Share Posted September 4, 2020 That did it!!! Thank you very much. Link to comment Share on other sites More sharing options...
rwdozier Posted September 5, 2020 Author Share Posted September 5, 2020 Ok, going crazy here... I thought I had this figured out, but now I can't get the wall brick to drop down to the brick ledge depth set at 8". What am I overlooking? Thank you. Plan_02_Help_X.plan Link to comment Share on other sites More sharing options...
glennw Posted September 5, 2020 Share Posted September 5, 2020 I see the same as Eric - all looks good. Are you sure that you deleted the old Auto Detail polylines and then Auto Detailed again. Auto Detail does not delete any previous auto detail polylines. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 5, 2020 Share Posted September 5, 2020 1 hour ago, solver said: This is what I see. 13 minutes ago, glennw said: I see the same as Eric - all looks good. Try opening it in X11 Link to comment Share on other sites More sharing options...
rwdozier Posted September 5, 2020 Author Share Posted September 5, 2020 Wow! How can I be sure I've deleted all of the Auto Detail polylines? Please see the camera view too, it shows the brick not on the lowered brick ledge depth. Link to comment Share on other sites More sharing options...
glennw Posted September 5, 2020 Share Posted September 5, 2020 3 minutes ago, rwdozier said: Wow! How can I be sure I've deleted all of the Auto Detail polylines? In the cross section view drag a selection marquee around all of the section. This will only select all the cad work - this is good unless you have already done any cad work. I haven't looked at what happens in X11 - only X12. Link to comment Share on other sites More sharing options...
rwdozier Posted September 6, 2020 Author Share Posted September 6, 2020 Ok, I started CA and selected New Plan, drew the same walls, built the foundation and all's good. But being that I like to see what caused this, I opened the problem plan file, did an Edit Area (all floors) and pasted into the new plan and did another cross section and it too has the same issue. I need to get going on this plan so I may not know what caused this. Thank you all for your replies!!! Link to comment Share on other sites More sharing options...
