builtright3 Posted September 3, 2020 Share Posted September 3, 2020 This is the kind of stuff that is very irritating to me!! If anyone can help me to easily find the problem when this happens I will be forever grateful! I can post the plan if needed but If I have some direction I would like to figure this out myself Thank You Link to comment Share on other sites More sharing options...
robdyck Posted September 3, 2020 Share Posted September 3, 2020 7 minutes ago, builtright3 said: This is the kind of stuff that is very irritating to me!! If anyone can help me to easily find the problem when this happens I will be forever grateful! I can post the plan if needed but If I have some direction I would like to figure this out myself Thank You If you post the plan, I'll take a look and tell you how I go about it. Link to comment Share on other sites More sharing options...
builtright3 Posted September 3, 2020 Author Share Posted September 3, 2020 28 minutes ago, robdyck said: If you post the plan, I'll take a look and tell you how I go about it. Thank you I will post it soon. Have to run out for a few. Link to comment Share on other sites More sharing options...
DzinEye Posted September 3, 2020 Share Posted September 3, 2020 I get those frequently... and almost always in that same exact roof/wall scenario. I've found that it can be due to two different things... sometimes there's an attic wall showing through, and sometimes if you click on that front garage-door wall you'll see there's a skinny offshoot of the wall going up... and I have no idea what causes that to happen, but I get those a lot. Sometimes moving things around a bit will make it go away on it's own but more often than not I just pull the offending offshoot down manually. Link to comment Share on other sites More sharing options...
builtright3 Posted September 3, 2020 Author Share Posted September 3, 2020 2 hours ago, robdyck said: If you post the plan, I'll take a look and tell you how I go about it. New Plan 103, Seaman, Steven.plan Link to comment Share on other sites More sharing options...
DzinEye Posted September 3, 2020 Share Posted September 3, 2020 @builtright3 Well...one solution without manually doing anything to the offending wall; if you uncheck flat ceiling over the garage it'll go away. I guess if you really do need a flat ceiling, then you could do a manual one? ... oh.. forgot to mention that I continued the exterior wall all the way through to the back of the garage, then in that walls roof panel chose an interior wall type for wall split by butting roof. Link to comment Share on other sites More sharing options...
robdyck Posted September 3, 2020 Share Posted September 3, 2020 @builtright3 Ok, I can't get it with a setting as quickly as I hoped, and now I'm out of time! But if you zoom in close, really close, then drag the lower side edge of the attic wall to the left, until its neatly aligned, the lines will disappear and the stucco will blend. Link to comment Share on other sites More sharing options...
builtright3 Posted September 3, 2020 Author Share Posted September 3, 2020 1 hour ago, robdyck said: @builtright3 Ok, I can't get it with a setting as quickly as I hoped, and now I'm out of time! But if you zoom in close, really close, then drag the lower side edge of the attic wall to the left, until its neatly aligned, the lines will disappear and the stucco will blend. Thank You! I tried to move that in every direction except for that one that you did. I guess this stuff just happens from time to time and we have to make it work. I wish there was a better explanation but I don't know what it would be. Link to comment Share on other sites More sharing options...
