SteveNovato Posted August 8, 2020 Share Posted August 8, 2020 I have a plot plan which shows the length of each side. One side is an arc and shows the radius, as well as the length. I want to turn off the radius information on the plan. I have angles 'off' but it still shows when the 'show length' box is checked. I guess I could cover the radius info with a white box, but that seems so amateur! I am hoping that someone out there has a solution... Thanks in advance. Steve Wright.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted August 8, 2020 Share Posted August 8, 2020 Yes it is all or nothing with cad line labels..... You could as you say palace a patch over the radius or turn it off and add the the length with text or if you want to keep it live you could replace your cad line with a room divider set to "No Room Definition" with a custom label macro. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 8, 2020 Share Posted August 8, 2020 3 hours ago, SteveNovato said: I guess I could cover the radius info with a white box, but that seems so amateur! Sometimes those little white boxes are your friend. I use them to make my dwgs more "professional." Just a different way of looking at it, I guess. Link to comment Share on other sites More sharing options...
SteveNovato Posted August 8, 2020 Author Share Posted August 8, 2020 Thanks for the advice. I guess simple is good... Link to comment Share on other sites More sharing options...
