Stair/Railing Question
sthieldesign
Need Stair Help:
I am having a double stair railing show up on my plan. How do I fix this? Attached is a picture showing the issue When I delete the left railing on a portion of the stairs is takes all the railing away.
Chief X12 Windows
4 hours ago, sthieldesign said:
Need Stair Help:
Chief X12 Windows
 Try disconnecting the Lower 3-4 Treads from the landing then turn off the LH railing on that section ...it shouldn't Hopefully then remove the Railing on the Upper part when you uncheck Railing>Left .
*** note the height on the Landing 1st , incase it drops to the floor when you disconnect the lower stair section - then just raise it up again if needed.
